Message 1 of 3
BT TV Box Pro
I have had a BT TV Box Pro for a few years now and generally it has behaved well. However, today it has started behaving badly.
It is connected to HDMI2 on my TV. However, when I switch to HDMI2 with the BT Box on, I get a "No signal" message. I have checked all the connections which are fine and connected it to HDMI1 (which I know to be working correctly) but with the same result. I have done a re-boot by pressing the centre button until it starts flashing, but that made no difference, and nor did disconnecting it from the electricity supply for a minute or two. Clearly I cannot do a factory reset as there is nothing to see on the screen.
What else can I try please?
2 REPLIES 2
Message 2 of 3
Re: BT TV Box Pro
@northshields
These instructions tell you how to Factory Reset a Box Pro even when there is no screen display:-
https://www.bt.com/help/tv/fix-a-problem/tv-boxes/how-do-i-reset-my-bt-tv-box-
If this does not rescue it, contact BT by phone and they will arrange a replacement.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 3
Re: BT TV Box Pro
Midnight_Voice,
Thank you very much for that. Following that procedure got as far as the logo appearing on the screen, but then that faded away and, once again, I was left with a blank screen. Looks like a phone call.
