Message 1 of 4
BT TV - MultiBox Limit
Hi,
First of all, my apologies if this is in the wrong-thread I tried to choose the most appropriate one.
I'm wondering while it's possible to have an Extra BT Box Added with the Subscription, is it possible to have a second-extra box? Which would go in another room of the house.
Any help you could provide with this would be most appreciated,
Have a great day,
James. S
Tags (2)
3 REPLIES 3
Message 2 of 4
Re: BT TV - MultiBox Limit
@JHStephenson Hi James, welcome to the community and thanks for posting. There is a two-box limit so you can have your main box plus one extra box.
Neil
Message 3 of 4
Hi, thank you for the warm welcome.
I see, thank you for the advice!
Message 4 of 4
I have a Pro Box and a mulitroom subscription with the IP Box. If I purchased another IP Box second hand (yes I know they are property of BT), would I be able to watch live tv on it too? I don't mind if only 2 are concurrent.
I know BT have a limit on the number of boxes they give you, but theoretically, would it work?
