Message 1 of 2
BT TV Pro Box Dropping Wifi
Hi,
I have been with BT for over a year for Broadband and TV.  I have a Smart Hub 2 and a TV Pro Box.
Recently the TV box has been dropping its connection to the Smart Hub.  Nothing has changed in terms of location of either unit.
I have tried a reset on both but it still keeps happening.  All other devices connected to the Smart Hub are fine.
Any suggestions, I have tried the help on BT and that is no Help.
1 REPLY 1
Message 2 of 2
Re: BT TV Pro Box Dropping Wifi
Hi James
Thanks for posting, when you say you have done a reset on the box was it a full factory reset?
Stuart
