Message 1 of 3
BT TV Pro remote
Hi i just recieved a new BT TV Pro box  the remote  source button does not work not even flashing when pushed was sent a new remote from BT but  this is the same have tried the reset  home and 9  also home and 7  the volume works ok the but does nit turn off tv  with long press the  set top box remote settings is  on tv  so dont no whats wrong  its a Sharp smart tv thanks Mike
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: BT TV Pro remote
Is the Pro Box connected directly to the TV rather than via an amp or soundbar?
If it is then you just be out of luck. A lot of TVs these days aren't made by the the company whose badge they sport. I believe Sharp are currently manufactured by Hisense. So it's possible that the HDMI handshaking that identifies the TV manufacturer may be selecting the wrong code. Sadly there's no manual setup so it either works or it doesn't.
The source button on the remote isn't meant to flash.
Message 3 of 3
yes connected directly to the TV  must not be going to work with my tv but thanks for your hepl
