Message 1 of 5
TV connection to WFI
New cable has been fitted at our property by UK Power networks now the TV is not connecting with WFI.
4 REPLIES 4
Message 2 of 5
Re: TV connection to WFI
What cable was replaced?
Who supplies your broadband?
Message 3 of 5
A new cable as in a electrical supply cable? Unless you've had a fault that potentially caused damage to your internal equipment in your home I doubt that it would be related.
Perhaps the outage of supply caused some equipment to lose settings you should just be able to go thought the setup process again.
Message 4 of 5
Hi @chris75 and welcome to our community.
Sorry for the late reply. Did you get this sorted?
Cheers
David
Message 5 of 5
Sorted thanks
