Message 1 of 3
BT TV box not recording
Hi all,
First time on here, my BT TV box won’t record in the planner when I press record, but it will record when I’m watching a program.
Any suggestions
Zthanks
2 REPLIES 2
Message 2 of 3
Re: BT TV box not recording
I’ve solved it
Message 3 of 3
Thanks @Icevanu  for confirming you solved the problem, Are you able to share with the community what resolved it ?
Often soft reset or powering  on/off of box may resolve many issues ?
