Message 1 of 6
BT TV box picture going dull
Morning
We have a bt TV box that records etc it's been fine but last night when you put the TV on and choose the box on hdmi the picture goes dull after 3 seconds.
I tried a factory reset it's the same and another hdmi socket
Any advice on this thank you
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: BT TV box picture going dull
Have you tried a different HDMI cable?
Message 3 of 6
No I'll try that
Message 4 of 6
I've got the same problem. Did you solve it?
Message 5 of 6
Hi yes changed the hdmi cable and was fine ☺️
Message 6 of 6
Changed HDMI cable  but that didn't cure it. Then checked my satellite receiver also connected by HDMI and that was the same. So deduced it must be my JVC  TV. Did a soft reset and all good again. Thanks for taking the time to answer.
