Message 1 of 23
IPC 6023 AND 6011
IPC 6023 is becoming a real nuisance we have had this problem for years no one seems to fix it. It has to be at BT s end
22 REPLIES 22
Message 2 of 23
Re: IPC 6023 AND 6011
Hi @57mo I'm really sorry about that and can appreciate the frustration it must be causing. IPC6023 is quite a generic error but it usually means the BT TV box isn't getting the packets of information that contain the TV steam.
Is the error there all the time or is it intermittent?
Also when this happens is the screen black with just the error showing or does the picture pixelate first?
Also, some more information on your TV setup will help us work this out, what model of BT TV box do you have, is it connected using an ethernet cable or powerline adapters or wifi if it's a pro box?
Neil
Message 3 of 23
It is intermittent.Black screen .
It has in-line  adapters we have tried all the things been told by bt still the same. Tried Ethernet and still comes up.
Think it is a configuration problem
Message 4 of 23
@57mo what model of box do you have? Configuration issues are normally not intermittent, if it was a network configuration issue it would never work.
Neil
Message 5 of 23
Not sure what the model is but has single button at the front  with red light on right side.
We paid for this box from bt
Message 6 of 23
@57mo take a look at this bt.com help page and let me know which one it is. If you're using powerline adapters have these been provided by BT and have you tried a reset on them? They use your electrical wiring to provide the broadband signal to the box and I suspect this is where the problem is.
If you have a pro box I would recommend connecting it via wifi to see if that helps.
Neil
Message 7 of 23
Yes it is pro box2
Message 8 of 23
I have had the same issue since Saturday morning. Spent 90 mins on phone to BT. Tried everything, nothing resolved. They are going to call me back on Tuesday morning to see if it’s resolved.
Message 9 of 23
We had it with broadband and still got it with fibre.
It is a bt problem.
Message 10 of 23
Thanks will try that tomorrow
