Message 1 of 5
BT TV box stopped working suddenly
Literally just this evening my BT TV box has just stopped working. I initially found it displaying only a red light on the left-hand side and now, when I turn it on, only the blue light on the left lights up and I'm getting a blank screen. I really don't want to lose my recordings. Is there anywhere - official or otherwise - where I can get it repaired?
I tried resetting it and nothing happened (apart from the single blue light as before - knowing what it even means would be handy but I see you've got rid of that service). I'm really upset about this, considering it was working fine less than a day ago.
Tags (1)
4 REPLIES 4
Message 2 of 5
Re: BT TV box stopped working suddenly
Hi @CHelfet01, welcome to the forum and sorry your TV Box is not working.
You could try a soft reset (keeping your recordings) How do I reset my BT TV box? | BT Help. If that doesn't work then you would need to factory reset the box and you would lose your recordings.
John
Message 3 of 5
I already tried the soft reset - I think I might have tried both. Is there no way at all I can recover the recordings? Replacing the set is no big deal
Message 4 of 5
Unfortunately not. If it's one of the older HD boxes, it's more than likely a hard drive failure.
Message 5 of 5
@CHelfet01  The user guides normally have the description of what the various lights  and colour s mean
https://www.bt.com/help/tv/getting-set-up/bt-tv-user-guides
