Message 1 of 2
BT TV error IPC6023
Hi
Since replacing router, problem with all BT Sport channels which freeze after 4/5 minutes. IPC6023 fault is then displayed.
It can be unfrozen by going to programme guide, selecting another sport channel and then switching back to original channel. It then freezes again after 4/5 mins.
Have followed advice [rebooting router, you view, mini connectors etc].
Any ideas would be appreciated.
1 REPLY 1
Message 2 of 2
Re: BT TV error IPC6023
Hi @DAV4
Welcome to the BT Community and thank you for your post!
I am sorry you're seeing error code IPC6023 on your BT TV service.  We'll be able to check what's causing that error and help put this right for you.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
