Message 1 of 4
BT box keeps going into maintenance mode
My BT box has being going into maintenance mode every night for the past week. Any ideas on how to fix this. Getting very annoying having to log back into all the apps, any help appreciated.
3 REPLIES 3
Message 2 of 4
Re: BT box keeps going into maintenance mode
Hi, @DuncanB101 I'm sorry that shouldn't be happening, I'd recommend trying a factory reset to see if that helps. Make sure to choose the option to keep your recordings.
Neil
Message 3 of 4
Hi @DuncanB101, did you get a chance to try the reset as recommended by Neil? If so did the box go into maintenance mode since then?
Cheers
John
Message 4 of 4
Hi @DuncanB101
Sorry to hear that you are having this problem, which model of BT set top box is it  that you are seeing the maint mode on?
