Message 1 of 9
BT box pro remote.
I have just got a BT pro box, everything works fine including the Bluetooth remote control. I have got a spare remote control (same bt one)so me and my wife can have one each. I can not get the new one to control the TV, ie volume, source, and off and on. I have tried the home and 9 button solution. Any thoughts would be appreciated.
It's not the size of the wand but the magic in the stick.
8 REPLIES 8
Anonymous
Not applicable
Message 2 of 9
Re: BT box pro remote.
Have a look at Bluetooth Remote under Settings. That's where you usually select what device volume the remote controls, but no idea how that would work with two.
Message 3 of 9
Virgin and Sky boxes will only allow one enabled remote at a time - would not surprise me if BT was the same.
Message 4 of 9
Had 2 working with my last but BT box but that wasn’t bluetooth.
Anonymous
Not applicable
Message 5 of 9
@ozsat
I wouldn't expect two to work either, but the OP seems to imply that it's only control of the TV that's not working.
@curlywatts?
Message 6 of 9
That's correct, I have both working on the box but only one will control the TV.
Message 7 of 9
Is the set-top-box remote setting set to 'tv' or 'set top box' ?
Message 8 of 9
Hi, TV.
Message 9 of 9
