Message 11 of 13
Re: BT pro box update.
@Anonymous I'm still on 4.0.250 / 0.6.152 !   Last check for update was 21/11/22.
Message 12 of 13
@Anonymous looks like you are the same as me. Those version numbers indicate that you are part of the YouView trial of a new interface (Feedback group should say yvurbtboxproux). You should have had an email from the YouView Research team explaining things. I emailed the YouView Research team to ask about the other software versions and this is what they said:
1. Was the delay in receiving the 4.0.246/0.6.124 and Visual Guide on demand updates because I was scheduled to be in the trial?
 There was a delay for all trialists just down to the way the way the software was deployed.
2. What happens after the trial is finished? Will the updates I am missing be downloaded to my Pro BoX?
You’ll get the missing software after the trial.
Anonymous
Not applicable
Message 13 of 13
@BillyM  That would explain why we are behind then.. Yes I am on the trial for a new feature. Just have to wait and see when it arrives.
