Message 21 of 25
Re: BT set top box
@Brucemeister5 naaa I keep my Usernames simple so I don't forget them 🤣
Message 22 of 25
Re: BT set top box
@Earthling wrote
As I thought then, but thanks for the info.  I did have the Manhattan, great initially but, as with many others, it became completely unusable after a month or so.  I understand there is an unexpired delay introducing the TVR4.  Not an option currently.
Manhattan-t4-t4r
Message 23 of 25
Re: BT set top box
I don't know if you have an old sky dish but many of Samsung's TV have a port for Freesat..
Was just a thought.
Anonymous
Not applicable
Message 24 of 25
Re: BT set top box
@Earthlingwrote:
@NigelB72    That's like our present setup - aerial plugged into a YouView box, HDMI connection to the TV.  The old YouView box doesn't do HD though so if we find we still need a box because TV Plus isn't right we'll have to get one.  Extra £400+ though, which we were hoping to avoid.
Where on Earth did you get a figure of £400+ from for a Freeview PVR?
Message 25 of 25
Re: BT set top box
@Earthling
YouView boxes have always done HD since the get-go. Did you mean UHD or what?
And where did you get £400 from as the price of adding a recording box?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
