Message 1 of 3
BT television
I'm thinking of changing over from Sky Q to BT as my main television provider. The main reason being the unremovable mini screen and sound that is on the screen on switch on. Does BT have a similar facility or does it show, say program listing on switch on with no sound. Thank you BryanF
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: BT television
When you turn on BT TV you get a transparent home menu overlaying the full screen view of the last programme you were watching, with sound.
Here is an older version to give you an idea:
Home ScreenHome Screen
I'm not aware of an option to change it.
Message 3 of 3
Re: BT television
Thank you Stereohaven not what I was hoping for hey ho
