Message 1 of 7
BOX PRO REMOTE
Is there any way I can turn off bluetooth on my remote?? as when i turn on the box, my Chromecast with TV switches on at the same time, very annoying!
6 REPLIES 6
Message 2 of 7
Re: BOX PRO REMOTE
I doubt that's anything to do with Bluetooth - try pressing the power button on the front of the BT box. I'd expect the same thing to happen.
Message 3 of 7
Re: BOX PRO REMOTE
Hi Darren, the Chromecast remote is also bluetooth!!
Message 4 of 7
Re: BOX PRO REMOTE
Yes, and so is your phone, maybe headphones too? Households have many different Bluetooth devices, but they're all uniquely paired - commands from one device don't affect any others.
Anonymous
Not applicable
Message 5 of 7
Re: BOX PRO REMOTE
@Jiffy1 I suspect the Chromecast turning on with the TV is more to do with CEC being enabled than a Bluetooth issue.
Different devices handle CEC either well or poorly, it basically enables devices to turn a TV on or off or switch input via HDMI.
Sky devices for example often break CEC, especially when connected to an LG TV for some reason, causing other attached devices to have issues. I had to buy a CEC HDMI blocker to fix it.
Otherwise you might find a specific CEC setting in the TV or Chromecast itself. Worth noting that it isn't always called CEC either, LG for example call it "SimpLink".
What is CEC (Consumer Electronics Control)?
Message 6 of 7
Re: BOX PRO REMOTE
Yes, thats a possibility too, will check my inputs for HDMI, there may be one that doesn't have CEC. Thanks.
Message 7 of 7
Re: BOX PRO REMOTE
You can turn CEC off from the display settings on your Chromecast with Google TV too.
