Message 11 of 13
Re: Bbc 1 hd via Internet mode no dolby digital.
excellent many thanks @ozsat
For bt this should be a simple fix.
While we are on the subject of the dolby logo. quite a few on sky cinema also have the tag missing, yet I can hear those.
Once the sound issue is fixed on the pro box, this will make things easier.
Message 12 of 13
It could be a general fault with their EPG system.
What makes you think the Box Pro fixed output audio format issue will ever be fixed? 😂
Message 13 of 13
This issue is still ongoing (incorrect metadata).
