Message 1 of 5
Best Remote For BT Box?
I'm not sure if all BT Youview remotes are interchangeable?
Just got a BT Box Pro which I like but the remote has no Sub button or Del button and no Fav button....
Can previous remotes for other BT view boxes be used if I get one off Ebay?
I see the BT BOX REMOTE CONTROL RC3124705/05B has a dedicated Sub/Del button...will that work with BT Pro box?
remoteremote
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Best Remote For BT Box?
Yes. Despite the Pro Box remote being bluetooth, the box also responds to the same Humax codes as previous boxes.
Message 3 of 5
@kingleygate
If you can get a Plusnet one with MyView instead of BT Player then that's the best. On the non-PRO units pressing the MyView button takes you directly to your recordings so hopefully would do the same on the PRO box.
Message 4 of 5
I use my old Plusnet remote with my Pro box and pressing the ‘My View’ or ‘My TV’ button (which later Plusnet Remote Controls like mine have) does indeed take you directly to your Recordings.
…………………………………………………………………………………………….………………………………………………..….…….…. My Services - Full Fibre 100, Smart Hub 2, EE Smart WiFi, Digital Voice with Alexa Phone, BT TV Box Pro, EE All Rounder Sim Only
Message 5 of 5
Thanks all I have ordered one today!
