Message 1 of 5
Remote not working
Hi my remote has stopped working for my extra box in bedroom I have tried everything and it won’t work 😞 just won’t connect how do I get a replacement
Tags (3)
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Remote not working
@Charleyk29  Have you tried a reset of the remote.  Press the purple home button and the number 7 at the same time  until it flashes blue the try using the remote as normal...
Message 3 of 5
Yeah tried that 😞
Message 4 of 5
Hi, @Charleyk29 I'm sorry your remote has stopped working, if you message the BT TV faults team on this link they'll be able to help.
Neil
Message 5 of 5
I think I have a similar issue - since the latest update I can't use my BT remote to control sound volume.
