Message 1 of 4
Bt Player knocks hub off
Every time  we try to use bt apps it turns the connection off at the hub, i have reset the box/hub and nothing has made a difference tried setting up with ethernet cable in tv still does not work.
iPlayer does the same thing, can anyone explain why?
3 REPLIES 3
Message 2 of 4
Re: Bt Player knocks hub off
Hi Mark74,
Thank you for posting. It sounds like you BT TV box is faulty. I think the last thing you could try is a factory reset of the box.
How to factory reset your BT TV Box
Give that a try and let me know how you get on.
Thanks,
Paddy
Message 3 of 4
Hi I have done a factory reset and it is still the same
Mark
Message 4 of 4
Thanks for posting back @mark74
Sorry for these problems.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
