Message 11 of 15
Re: Bt TV box Pro and BT Home Hub 5 router
Thank you so much SRB!
Just what I wanted to hear and backs up what Tim has said.
I will need another returns bag!
Regards
Edward
Message 12 of 15
@efelstead
Don't return any new HomeHub that might get sent as if yours fails you've got a replacement on hand rather than maybe 3 or 4 days to get a replacement.
I'm a follower of the "It'll come in handy"  brigade. 😀
Message 13 of 15
And not the punctuation brigade. 😂😂😂
Message 14 of 15
Well, obviously that's what my old Home Hub 3 is for 😂
Message 15 of 15
Hello
Update re installing BT TV Box Pro
I installed the box yesterday using the  Home Hub 5 and all went perfectly.
So far everything is working as it should  so unless something unexpected happens i can only conclude that it is not absolutely  necessary to change the router to the latest Smart hub
Thank you all who responded to my post
Regards
Edward
