Message 1 of 4
Bt box freezes after update
Every time there’s an update my bt box freezes as in the remote won’t work and the buttons on the box won’t work so I have to do a factory reset every time which is annoying,also there’s a lot of failed to record recordings on my box too .
I have the humax DTRT2100 model
3 REPLIES 3
Message 2 of 4
Re: Bt box freezes after update
Hi @Chez85, welcome to the forum and thanks for posting.
How often are you having to factory reset the box?
Cheers
John
Message 3 of 4
It only recently started to happen and it’s been  roughly two weeks apart since it started.
Message 4 of 4
Hi @Chez85, the box may need replaced. If you have a BT TV package it will be under warranty.
I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to look at this for you.
Cheers
John
