Message 1 of 6
Bt hd and 4k bolt on
Not sure and may be a stupid question, but what is the hd and 4k bolt on actual for ?  Is it just now.tv content, cant see why i am paying for some that i am not using.
i am assuming the freeview standard HD channels arent affected by this ?
5 REPLIES 5
Message 2 of 6
Re: Bt hd and 4k bolt on
The add ons are to give a higher resolution TV picture, assuming your TV can display the higher resolution, not all TVs can.
See links
BT 4K Ultra HD TV | BT Help
BT TV HD channels and add-ons | BT Help
Message 3 of 6
But is that for all content in the bt box or just Now tv ? ,
the way i see it freeview channels are hd anyway and 4k is usually available for bbc on the iplayer
Message 4 of 6
Have a read through all the sub links in the links I posted, they may be able to answer your questions.
Message 5 of 6
Looks as clear a mud, ive cancelled it anyway cant see the point of nearly £6 a month for something thats free on the standard channels and no longer watch now.tv
Anonymous
Not applicable
Message 6 of 6
Hi @paulosjonesos
Your gut instinct is correct, the HD/4K add on is a monthly fee that provides access to any subscription channels (NOW, AMC, BT Sport), in HD (or 4K in the case of BT Sport Ultimate), alongside the standard definition versions.
If you are using an aerial to provide your Freeview channels, the HD/4K add on has no impact, same for any apps such as Netflix, Prime Video, itvX, My5 etc.
If you using a BT TV Box Pro and are accessing the IPTV versions of Freeview channels, the HD/4K add on has no impact, same for any apps such as Netflix, Prime Video, itvX, My5 etc., although you do need a minimum BT TV subscription (such as Entertainment, even the standard definition version), to access IPTV channels.
Depending on the box you have and when you acquired it, if you don't have a BT TV subscription, you can't just keep the box and use it as a Freeview PVR without some form of BT TV contract. It has to be returned or you will be charged up to  £115.
