Message 1 of 5
BT TV Subscription ending - Can I still record programmes on BT Box?
I have a BT Pro Box, which I purchased myself, but I have now cancelled my BT Sport subscription which in turn cancels my BT TV. My question is will I still be able to record programmes on the BT Pro Box without the subscription to BT TV? If I can will that only be through Freeview?
4 REPLIES 4
Message 2 of 5
Re: BT TV Subscription ending - Can I still record programmes on BT Box?
It should work as a Freeview recorder via an aerial connection
Anonymous
Not applicable
Message 3 of 5
@DAM555 Yes, but only if you have an aerial plugged in to receive the Freeview channels.
If you bought it yourself, you shouldn't need to return it.
Message 4 of 5
Thank you
Message 5 of 5
Thank you
