Message 1 of 12
Bt pro box
Recently installed new bt pro box I thought I could record 4 shows simultaneously but throws a warning saying 2 only
any ideas why this is
11 REPLIES 11
Message 2 of 12
Re: Bt pro box
Are you getting your channels through an aerial or through the internet?
Message 3 of 12
Re: Bt pro box
Thanks David Through internet
Does that make a difference then
bt never mentioned this when I upgraded!!
Message 4 of 12
Re: Bt pro box
Through internet
Message 5 of 12
Re: Bt pro box
Yeah through the internet it's only 2 channels.
It's all down to bandwidth etc. There's a post about it somewhere.
Message 6 of 12
Re: Bt pro box
this is the post
https://community.bt.com/t5/YouView-from-BT/BT-TV-without-the-need-of-an-aerial/td-p/2246295
Message 7 of 12
Re: Bt pro box
Ok didn’t tell me that
Having fibre installed will this increase the recordings
Message 8 of 12
Re: Bt pro box
Negative.
Message 9 of 12
Re: Bt pro box
Ok but I can plug aerial in and then will it allow 4 recordings
Can I use both internet and aerial 🤨
It’s funny nowhere does it say only 2 recordings if via internet!!
Message 10 of 12
Re: Bt pro box
in the link I posted it shows
How many channels can I record if I go aerial free?
Using aerial mode you will be able to record 4 channels at once.  If you use internet mode then you will be able to record 2 channels at once.
