Message 11 of 12
Re: Bt pro box
Bt restrict the box to receiving 2  multicast Ip channels simultaneously  so effectively you could record 2 IP channels , or record 1 and watch another IP channel. So in IP mode two is the limit.
In aerial mode the box is able to receive 4 Freeview channels so  up to 4 simultaneous recordings of the Freeview channels can occur. The same restrictions on IP multicast channels  apply so 2 IP multicast channel can be recorded.  So in aerial mode you could record  up to 4 aerial channels  plus upto  2 IP multicast channels so up to 6 recordings.
Message 12 of 12
Re: Bt pro box
Thank you it’s working now but lost all new tv package channels so going to wait see if the fibre install sorts
