Message 1 of 3
Bt tv
Hi I’m thinking about getting bt tv but I’m not very tech minded … how easy is it to set up and do you pay a base price then add on packages you want or do you get different price bundles etc ?? Thanks
2 REPLIES 2
Message 2 of 3
Re: Bt tv
It's very easy to set up and you choose a base package but you can change it each month.
Message 3 of 3
Re: Bt tv
Hi @H-W and welcome to our community.
You'll find all the information you need about BT TV at https://www.bt.com/tv/. Thanks also to @NigelB72 for the great advice.
Cheers
David
