Message 1 of 3
Can you get the full range of Freeview channels on EE TV mini box if using an Aerial on the Pro Box?
Not sure this exact question has been asked before as have tried searching to find an answer. Question is if I have a freeview aerial attached to the EETV Pro Box can I watch the same full range on Freeview channels on the EETV mini box? There are are a number of channels my partner would like to watch on the mini box e.g. QVC, Dave etc.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Can you get the full range of Freeview channels on EE TV mini box if using an Aerial on the Pro
@SWL
The answer is 'no' and that is because the mini box does not use an aerial or connect to the Pro Box in any way.
It only receives the Freeview channels delivered via your broadband which is not the same. The list of which channels are available is here.
Message 3 of 3
Thank you. That's a shame.
