Message 1 of 3
Second BT Pro Box
I have a pro box all set up and running perfectly but, I have acquired an unused second box from a deceased family member and was wondering if I could use this box to access freeview through the aerial and also I assume I could you use it to record programmes, finally the box would be in the same room as my box that is working perfectly with BT but would a second handset interfere with the my original Pro Box.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Second BT Pro Box
The box is only on loan, so I would expect that whoever has dealt with the deceased's account to be asked to return it.
But other than that, yes it will work as a Freeview PVR.
The remotes are bluetooth so shouldn't interfere with each other.
Message 3 of 3
Thanks. I don't even know if his account has been closed I will find out about it. Thanks for your reply.
