Message 1 of 3
Changed TV Package
Hi all
I changed my TV package yesterday do so need to do a reset of my box for the change to take effect?
Many thanks
Sarah
2 REPLIES 2
Message 2 of 3
Re: Changed TV Package
No.
You might find a message come up on screen which requires you to press OK to add the new channels to your plan but you should only have to do it once and one press will not commit you to buying anything you haven't already signed up for
Message 3 of 3
Many thanks!
