Message 1 of 5
Re: I have tried several times to change my TV package and I am getting nowhere, why?
Can I ask a related question here instead of starting a new thread?
If I want to switch packages between BT Sport and BT Big Sport (and then back in a few months) can I do it online and how much notice do I need to give for it to take effect?
Is the charging period a calendar month or a month from the date of my bill?
Thanks.
4 REPLIES 4
Message 2 of 5
Hi @SteveG2460 Thanks for posting, I've started your own thread to avoid confusion with the op's issue. In answer to your questions if you have a BT TV flexible plan you can switch between plans every 30 days. You can make changes to the package online in MyBT and the change should happen within 24 hours. The charging period is a month from the date of your bill.
Neil
Message 3 of 5
I wasn't sure whether I should create a new thread or not so thanks for setting this up and answering the question NeilO.
So basically the package month can be different from the billing month which of course makes sense as it makes it much more flexible.
Message 4 of 5
Hi, @SteveG2460 no problem. Yes, the package can be changed every 30 days and is not connected to the billing month.
Neil
Anonymous
Not applicable
Message 5 of 5
Hi, Apologies for jumping in on this thread.  I have Big Sport and my current contract ends August 10th.  I was looking to swap my big sport for entertainment package.  When I log in to MYBT and find the page I need to swap package all the options I get involve re contracting for another 24months on my broadband. Which I don't want to do yet. There is no way to downgrade package to cheaper one ie entertainment.
