Message 1 of 3
Changing between modes on EE TV
How do I put my box in Aerial mode? I can't find it in settings. Tx
2 REPLIES 2
Message 2 of 3
Re: Changing between modes on EE TV
Hi @risingsun561
Thanks for posting and welcome to the community. I've moved your post to a new thread as it could be helpful for others in the future.
To change between aerial and ip modes on EE TV please see this link below:
About Aerial and Internet Modes on EE TV | BT Help
Stuart
Message 3 of 3
The official  advice there involves wiping all recordings by doing a factory  reset via the box menus . Recordings  can be preserved if performing a factory reset keeping recordings (using the box Pro reset button  NOT the menu) as described in https://www.bt.com/help/tv/fix-a-problem/tv-boxes/how-do-i-reset-my-bt-tv-box- (click on the box pro image to see the reset using button instructions) So if you have no aerial connected to the box before you start the factory reset (keeping recordings) you get the Ip Mode setup. If you have a functioning aerial  connected you get aerial mode.  Haven’t personally gone through this process for a while.
Note that if your box in aerial mode any freetoair Recordings made whilst previously IP mode will not be playable.
