Message 1 of 7
Clear history in My TV
How do I clear the history of pending recordings in My TV?
6 REPLIES 6
Message 2 of 7
Re: Clear history in My TV
You mean you want to cancel them? Press the record button, and select cancel.
Message 3 of 7
The history, to which I refer, displays a list of pending recordings that failed and are now past their broadcast time; they are therefore not outstanding.  I've tried highlighting the entries, in the hope there would be an option to delete the entry but that doesn't work.
There is a History tab in My TV - that's where the still pending but failed recordings are displayed.
Message 4 of 7
Is this in the app on your mobile/tablet? Or on the BT TV box?
Message 5 of 7
On the Android app.
Message 6 of 7
Ah OK - there's currently no option to delete from the history. It'll disappear automatically after 7 days.
Message 7 of 7
Ah, ha!  Thank you.
