Message 1 of 7
IPC6023 error message BTTV
Hello
My BT box pro was working fine until about a week ago.
Now, I can't view any channels at all. I keep getting the IPC6023 error message.
I have reset my router twice and factory reset the box but it's still not working.
My broadband speed is fine and my BT sport channels still work if I watch via the Discovery plus app.
Can a moderator please help me escalate this issue.
James
6 REPLIES 6
Message 2 of 7
Re: IPC6023 error message BTTV
Hi @JimYorkUk and thanks for posting.
I'm sorry you're seeing the IPC6023 error message. How is the box connected? Is it wireless, through adaptors or directly via cable?
Cheers
David
Message 3 of 7
Hi @DavidM
Thanks for your help. It is connected via WiFi.
I have BT broadband with a smart hub 2 router and a WiFi extender disk. The WiFi signal is good and broadband speed is good.
BT Sport plays fine through the Discovery plus app but I can't get any channels on my BT box.
Thanks again for your help
James
Message 4 of 7
@JimYorkUk Thanks for getting back to us, for testing purposes can you connect via an ethernet cable to see if the error remains?
Neil
Message 5 of 7
Hi @NeilO @DavidM
I have tried connecting via ethernet just now and the error is still there.
James
Message 6 of 7
Thanks for checking that @JimYorkUk .
We'll need to take a closer look at this for you so please check your inbox for my message and drop me over the details.
Cheers
David
Message 7 of 7
Hi @JimYorkUk .
Just for the benefit of the community, I can see our specialists have been in touch and have sorted this for you.
Cheers
David
