Message 11 of 12
Re: Connecting EE TV app to wired TV box
@DarrenDevwrote:
The mDNS is only used for pairing. Once paired, all EE TV app communication is via the cloud.
If you want to cast to the TV Box from Netflix or YouTube though ...
Thanks for clearing that up mate, that makes sense as I was wondering that earlier because of course its possible to access the box outside the home....
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 12 of 12
OK, DarrenDev beat me to it, and with a proper explanation. Thanks.
Thanks for the suggestion, but the tablet is reconnected to the mesh network and the app is working fine. My phone is only ever connected to the mesh WiFI network, although it must have been connected to the hub WiFi network when I installed the app.
It appears that once the app has found the hub and connected to it for the first time, it doesn't care what WiFi network the tablet or phone is subsequently connected to. This is useful because it means I can schedule recordings when out and about and not on any of the home networks.
