Message 1 of 3
Connecting TV to BT Hub 2
Hope this is posted in correct board..... I recently installed BT (EE) TV box and see that ethernet cable is connected from TV Box  to LAN port on Hub 2.   Before I installed the TV Box I had an Ethernet cable running direct from back of TV to LAN port on BT Hub.   Do I still need to use this TV to Hub connection ?
2 REPLIES 2
Message 2 of 3
Re: Connecting TV to BT Hub 2
The LAN cable to your TV will be there to support the smart features of your TV - e.g. any apps installed on it. If you don't use them, then you don't need it connected.
Message 3 of 3
Many thanks, may as well leave it connected.
