Message 1 of 13
E4 not recording
My BT youview will not record E4, other recordings on other channels working fine.  Did a factory reset didnt help, any suggestions?
12 REPLIES 12
Message 2 of 13
Re: E4 not recording
It could be a deliberate setting by E4.  At least on Freeview, there has always been the ability of broadcasters to flag content as non-recordable!  I would assume that the same carries over to YouView and Freeview Play.
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 13
Is the problem with E4 provided on aerial feed or are you using IP mode On the BT Tv Box Pro ?
If aerial feed it could be a problem with a multiplex on the transmitter you are receiving your signal from.
Message 4 of 13
  • Thanks yes aerial feed so weird shows in scheduled just never actually records and so far only an issue on this particular channel
Message 5 of 13
Is it only scheduled recordings that fail? What happens if you press record for the current programme you're watching?
Also, are you setting the schedule from the box itself? Or via a paired app?
Message 6 of 13
I noticed yesterday that, although the EPG looked correct for E4, when I pressed the Information button it was still showing the previous programme details. That is why mine didn't record.
Richard
Message 7 of 13
Only scheduled recordings are failing
Message 8 of 13
I do recall Youview working earlier this year with the D3&4 multiplex people over some issues not too dissimilar to what you are experiencing. As their (Youview) community has closed I can’t look back at those discussions nor raise any questions with them.
Would suggest Bt check with Youview.
Message 9 of 13
Thanks for the pointer @zulu17 ... we've made YouView aware of this thread.
Message 10 of 13
YouView have been unable to reproduce this issue.
Is it still happening for you? Which model TV box do you have?
