Message 11 of 13
Re: E4 not recording
Hi no it seems to be fixed now, must of been an intermittent fault
Message 12 of 13
Hi!, Same thing happened in our household last sunday (23rd), had programmes on E4 down to record, but the recordings never worked, when i checked the tv guide on the box , all the programmes were either blank or rather scrambled in the incorrect order, intresting thing is, this was not on our BT Pro box, but on a Freesat box in another room, so it seems not only youview boxes were affected by this.
Message 13 of 13
I sometime have this sort of thing and suspect it is down to an old series link for the channel concerned leaving a ghost timer for a programme that has been moved or deleted that overlaps the new timer you are wanting to set.
This can usually be resolved by deleting all timers for that channel and resetting them. A manifestation of the buggy EPG/timer code when programme timings are changed by the broadcaster.
