Message 1 of 3
EE Pro Box
When I had a BT Youview box I could go into MYTV/Watchlist and see all the programs I had scheduled for the following week or so, the EE Pro Box does not seem to offer this, it only shows when it has been recorded, the only way to know if I have set them up is to keep checking the guide.  Having said all that it maybe a case of Age v Technology on my part and I'm missing something simple.
2 REPLIES 2
Message 2 of 3
Re: EE Pro Box
From your description I suspect that you are after the "Scheduled" list.
Open the Menu, and on the left there will be vertical list of options.
Press the left key, and the Home option will be displayed.
Go down the list and select My TV.
On the My TV page the "Watch List" is right next to the "Recordings" list, and just to the right of that is the "Scheduled" list.
Another point to note when your in this part of the menus is that "Recordings" will include all your recordings.  Reading between the lines you may have been always using the shortcut list of recordings, and that only includes up to 10 recordings.   If so then you wouldn't be the only one, and it's not surprising that you then also lost sight of where the Scheduled list was viewed
Message 3 of 3
Re: EE Pro Box
Hi Luke
Thanks, Yes I see it now, not as easy as the old BT Youview Box.
Thank You
