Message 1 of 6
EE TV modem questions
I'm looking at taking up EE broadband and TV on a new FTTP connection.
1. I understand that to use the TV recorder I will have to use the provided modem rather than my own. Is that correct?
2. Assuming 1. is correct.   I have my own router feeding a complex ethernet network and WiFi mesh.  Will I be able to get a feed from the supplied modem that will allow me to use my own router without double NAT problems?
5 REPLIES 5
Message 2 of 6
Re: EE TV modem questions
@RGing
You would be best asking the question on the EE forum.
https://community.ee.co.uk/
Message 3 of 6
OK Thanks.  I found EE TV and thought this would be the place. I'll try there.
Message 4 of 6
@RGing
Its simply that BT TV is now EE TV, for those that are still with BT Broadband. Its just a branding change showing up on the TV boxes.
As you are thinking of moving to EE, then I would be a bit wary at the moment. Take some time to read the comments on the EE forum first.
Message 5 of 6
@RGing @Keith_Beddoe
The Pro box remains the same; although it has a new EE livery, this is just cosmetic.
BT Broadband customers will stay with BT and the BT Smart Hub 2, though BT has now rebranded to EE.
EE Broadband is a whole other service, delivered over an EE router that is rather different from the BT Hub 2.
There are some aspects of this rebranding that still need a little more thinking through 😛
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 6 of 6
That's not entirely true either @Midnight_Voice - only the fastest broadband speeds will get the new EE router. Slower speeds get a rebranded Smart Hub 2.
To answer the original questions:
1. Some people have had success using their own router - it depends how well it supports Multicast. Search these forums for your device to see if it has been discussed. This configuration won't be supported though - if you have any issues with TV or broadband, you'll be required to switch back to the provided router to diagnose them (the router also has a number of diagnostics and monitoring tools built in).
2. There's no ability to use the supplier router just as a modem, so you will end up with double-NAT. Whether that causes you any issues depends on what you use it for.
