Message 1 of 4
EE tv
Hi, bit of a long shot but is there a large remote for partially sighted/elderly that will work with the EE tv box or an app that you can change the channel over etc if they get stuck using the remote. Thanks
3 REPLIES 3
Message 2 of 4
Re: EE tv
The EETV box has IR capability so you could buy a giant programable remote and program in the EETV Code (4031), thats the EETV Pro Box code that works with my One For All Remote, I got myself a URC1240 but the buttons I dont think are any bigger easier to see than on the stock remote. In theory I dont see why you cant get a programmable giant remote and achieve the same.
I dont think you can use the EETV App to remote control though.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Anonymous
Not applicable
Message 3 of 4
Re: EE tv
Have a look at the URC6810 or 6820.
Message 4 of 4
Re: EE tv
Thank you, will try one and see how she gets on.
