Message 1 of 11
Eurosport Recordings ...
WSBk & BSB sessions recorded Friday/ Saturday wont play back - esoteric error condition suggesting Internet not connected - which it is ..
Picking a current EuroSport 2 Prog & recording for a few mins plays back just fine  similary, recording the Highlights session for both events on Saturday evening was fine ...
I have the Humax 4K Box & the 'Sport' subscription via BT & things have been fine this season up to now ...
About to check if Sunday AM sessions have recorded .... [ All MotoGP Progs on Friday & Saturday recorded & played Back OK - so nowt wrong with Internet overnight Friday & Saturday ...]
Any ideas why the Box thinks things are awry with EuroSport ?  Dont think its taken any updates of late ?
10 REPLIES 10
Message 2 of 11
Re: Eurosport Recordings ...
Do you have EE TV app on a connected mobile that gives any clues  (more information)  about the problem recordings ?
Is it the Eurosport 2 SD or Eurosport 2 HD channel that you were recording ?
What error code or message are you actually being presented with ?
Are you using other  Youview boxes or an apple Tv  box EETV app as well as the T4000 ?
Message 3 of 11
No Mobile APP available.
its EuroSport 2 SD   ...
No error code   ... message in a Box saying Recording Not available due to lack of Internet access ...
No other YV Boxes, nor APPLE TV Box - just my trusty old T4000
Message 4 of 11
Curiouser & Curiouser !
All EuroSport 2 recordings have worked and are Viewable - again MotoGP on TNT Sports 2 was fine ....
So what was all that about previously   ... some sort of eligibility glitch ?
Message 5 of 11
There would be a check when you start to access the recording that the channel is one that you are subscribed to.  So any broadband  or network glitch at that time or anything that would cause the channel to appear not to be setup for your box would cause an issue. Of course the isue could be in the network or at the (youview/BT) server end at the time, the fact you experienced it on several recordings  on one channel  only suggests to me  it is probably not a box or home issue .
Message 6 of 11
Thx Zulu !
Could certainly have done w/o it - PitA !
Message 7 of 11
Probably won't want to bother now but at the time you could have fallen back on the Discovery+ app to watch those Friday sessions.
(the reason I prefer to record them if being broadcast is that it is less of a faff to skip through the chit chat to get to the next bit of actual action - especially given the glut of bike racing this weekend with MotoGP also in the mix ... not to mention keeping on top of the football, rugby and cricket!)
Message 8 of 11
Thx Gomezz ....
I actually recorded later the Highlights of the 'failed' Race recordings - so didnt miss too much ! [which mystified me a tad as they recorded & played back OK.- but it solved the problem]
Dont like the Discovery+ setup - hard to find stuff !
Message 9 of 11
Easiest way I have found for BSB and WSB is to tap on Sports then scroll down to Latest Events where there will be a BSB entry and a WSB entry.
Message 10 of 11
If it’s something that you watch regularly it should appear in your Watch List (within Recordings and Watch List ) and you can simply scroll along to the one that you want without having to go into Discovery+ to search for it.
