Message 1 of 10
Error codes + certain channels
I have a YouView box and the error code IPC6023 comes up on certain subscription channels. My broadband is fast so I don't understand why I cannot access these programmes. How do I solve this problem,  I have done all the things suggested restart the box, restart the broadband,  check the speed nothing changes!
9 REPLIES 9
Message 2 of 10
Re: Error codes + certain channels
Hi @A04 and welcome to our community.
Thanks for posting about the error code, sorry you're having problems. Can you confirm how is the TV box connected? Is it directly to the hub or via adaptors?
Cheers
David
Message 3 of 10
It is connected directly to the hub. The electricity was turned off yesterday, when it came back on that's when the problem started!
Message 4 of 10
Thanks for clarifying that. Can you list what channels are affected?
Cheers
David
Message 5 of 10
The subscription channels such as SKY news etc.
Message 6 of 10
@A04 Thanks for clarifying that, have you tried connecting the ethernet cable to a different port on your Hub?
Neil
Message 7 of 10
Yes I have tried that! Do you think re-setting the box would work?
Message 8 of 10
Hi @A04 Yes, that would be the next step to try.
Neil
Message 9 of 10
I am unsure how to do that. I am assuming it's not just unplugging it!
Message 10 of 10
Hi @A04,
Can you take a look at the following page Reset BT TV Box?
It should show you how.
DanielS
