Message 1 of 5
Extra box
How do I actually add extra box to my Bt tv package? Thanks
4 REPLIES 4
Message 2 of 5
Re: Extra box
Hi @andrew33, welcome to the forum and thanks for your post.
Check out Can I watch BT TV in more than one room? | BT Help for information on Extra Box and there is a link so you can order online.
Cheers
John
Message 3 of 5
Re: Extra box
Thanks for getting back to me. When I click the link, it gets me to sign in, then takes me to the tv package bit, but I can’t see anything about extra box at that point as an add on option.
Message 4 of 5
Re: Extra box
Hi @andrew33, sorry the link doesn't take you to the place to order the extra box. Give us a call on 0330 1234 150 and our customer services team will be able to order it for you.
Cheers
John
Message 5 of 5
Re: Extra box
All sorted. Thanks!
