Message 1 of 6
Failed to record
Up until a few days ago I had records ready to watch all recorded ok, now all of sudden they are saying failed to record. All new recordings are fine
5 REPLIES 5
Message 2 of 6
Re: Failed to record
@Rummer
That’s a sign of disc corruption 😢 And it will likely happen again.
Your best bet is a Settings/Factory Reset, but watch your recordings first while you can.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 6
Thank you have already done a reset on box. i will see how it goes then maybe request an engineer or new box
Message 4 of 6
@Rummer
I don’t think they would send an engineer for that, and even if they did, I don’t know what he could do, beyond Factory Resetting it, and you’ve already done that. (Though it was a full wipe-your-disc-drive Factory Reset, I trust?)
A new box is your best remedy.
Message 5 of 6
@Rummer  which box do you have  ( the Device Information under Settings  will give you the Manufacturer  and Model details if you are unsure )
Message 6 of 6
Sagemcom RTIW387,,,seems to be ok at the moment
