Message 1 of 37
No picture.
Turned on this morning and all was fine. Turned off after a bit, came back in about 20 minutes and turned back on. Am getting sound but no picture.
36 REPLIES 36
Message 2 of 37
Re: No picture.
Sound and picture come in by the hdmi cable, if you are getting one but not the other I would start there.  Check it's in fully or try another port on the TV - failing that perhaps a new cable.
As you are getting sound then you must be on the correct input for the box
Message 3 of 37
Re: No picture.
I changed out the HDM1 cable and the same result, sound on everywhere including the internet channels but no picture.
Message 4 of 37
Re: No picture.
Are the box menus displaying normally ?
what happens when you use say BBC iPlayer  and ITVX apps on the box , do they also have no picture and sound  ?
Message 5 of 37
Re: No picture.
Without the on-screen guide I don't know how to access the apps. I know the channel numbers for some of the internet channels such as 341 etc.
Message 6 of 37
Re: No picture.
Can't access menus as no picture,
Message 7 of 37
Re: No picture.
If you restart the box (holding the BT or EE button ) on the box for about 10 seconds or after the box has been powered off  does the Youview (may possibly be EETV these days) logo appear on the screen when the box starts before the screen then goes blonk ?
Message 8 of 37
Re: No picture.
No. Power lights are on but nothing while it presumably retunes except a black screen then sound comes on but screen is black.
Message 9 of 37
Re: No picture.
Should I try disconnecting box and plug TV in directly to eliminate problem with box?
Message 10 of 37
Re: No picture.
I would power off both the EE TV box and the TV for a couple of minutes and then power on the TV (only) . Do you have a smart TV with its own set of apps. ? Do the TV own menus display on screen ?
If they do then switch power  on the EETV again and see if any change ?
Which TV (brand and model is it ?
any other TVs in the household ?
