Message 1 of 1
Fault IPC6023
So I have, reset box, reset the router, disabled snooping, and enabled snooping. Wired, wireless. Changed cables to Cat 6E I have wifi streaming at 400-450mbps
BT Box all apps work, I can watch what was on yesterday, but can I stream live TV NO!!
Is there any way to disable this passthrough issue so I can use the BT box without having to revert to the Smarthub?
