Message 1 of 4
BT TV Pro Box Mesh WiFi issues
Hi All,
We have BT Fibre 500, apartment is too large to use just use home hub.
Tried Asus and Now Netgear mesh systems, BT TV Box will not work with these mesh systems.
Apps on the box work, guide works, rewind TV works by going into apps, but I can not get it to live stream TV.
Getting the following errors:
IPC6011
IPC6023
Other equipment, Naim Audio, Samsung TV, Sonos all stream with no issues??
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: BT TV Pro Box Mesh WiFi issues
You just need to enable multicast/IGMP which I believe both manufacturers support.
Message 3 of 4
Tried that on the Netgear no change?
Message 4 of 4
Orbi does not support IGMP snooping. Only IGMP proxying on the WAN port is supported. It doesn't seem to make a difference however I set it ?
