Message 1 of 2
HD Package
Hi. I recently cancelled my Netflix 4k subscription due to cost. I can now see I only get Netflix in 720p. Picture not bad but 1080p would be better.
If I took out BT HD subscription at £6 would I then get Netflix in 1080p? or is it just for Now TV? Seems a bit expensive for just Now TV which we rarely watch.
IGNORE THAT! Have just noticed HD Netflix £4 Thanks anyway
1 REPLY 1
Message 2 of 2
Re: HD Package
I know you found your answer, I just want to clarify that Netflix packages need the correct tier for UHD, the HD addon from BT does not change Netflix content.
