Message 1 of 13
Cannot play HD recordings (Error code IPC6041)
I am unable to watch most HD programmes that I record on TNT Sports, Eurosport and Now as I receive the message ‘Recording unavailable’ error code IPC6041. As an example if I record TNT Sports, I can watch programmes recorded in SD but not HD. It’s a similar result for, for example, Sky Nature and Sky Sports Premier League. However, a real oddity is that I can watch recorded Eurosport 2 HD programmes, but not Eurosport 1 HD programmes.
it doesn’t appear to matter if I record at the time of viewing or from the guide.
I have all the channels included in my package.
12 REPLIES 12
Message 2 of 13
Re: Cannot play HD recordings (Error code IPC6041)
Hi @blissett and welcome back.
It's been a long time but great to see you again. Sorry you're seeing the IPC6041 error code. Can you try the help at What do the EE TV error codes mean? | BT Help and let me know how you get on?
Cheers
David
Message 3 of 13
Thanks for your reply. I followed the steps but they made no difference.
Message 4 of 13
Actually, I didn’t click on update apps as the software information stated that the last check was today. However, I’ve just clicked to update apps and received a message to say ‘We can’t update your apps’. I’ll try bt.com/tverrors
Message 5 of 13
I can’t find the solution
Message 6 of 13
Thanks for checking that @blissett
How is the box connected? Is it wireless or cable? Are you using any extenders or adaptors?
Cheers
David
Message 7 of 13
The box is connected by cable to extenders
Message 8 of 13
Thanks again @blissett . Are you able to connect directly to the hub for testing?
Cheers
David
Message 9 of 13
Not without disconnecting everything and lugging it upstairs, which I would rather not do.
It just seems very odd that I can watch TNT, Eurosport and Sky (Now) HD channels but can’t record (and watch) them with the exception of Eurosport 2. There doesn’t seem to be any logic to it.
Message 10 of 13
I have plugged the BT box directly into the router but it made no difference.
